TwinTurbo.NET: Nissan 300ZX forum - Makes sense, previous owner had the det sensor bypassed
Subject Makes sense, previous owner had the det sensor bypassed
Posted by -Grimm- on September 20, 2013 at 9:55 AM
  This message has been viewed 234 times.
In Reply To Re: Bearing Condition - Your Opinion posted by Tech@EPR on September 20, 2013 at 04:03 AM
Message probably to milk boost out of it, meanwhile destroying everything inside the engine.
My only concern with purchasing an 'off the shelf' set of bearings is the variance in clearance. I would like to avoid having to remachine the mains and crank if possible.
I'll have the shop check the main condition/alignment while its there, I suppose if it needs to have the mains line honed then it wouldn't hurt to have the crank polished and standard bearings clearanced.
Do you aim for a different clearance than the FSM (~0.0016)?
